8ga Power to 22ga power wire?
  • 8ga Power to 22ga power wire?
    How do most of you guys connect your thick power and ground wires to the tiny 22ga Opus supplied wires? Currently i have them connected together via a terminal block but i dont like that!....How do all of you do it?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    bump anybody??
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
      If all mean, solder and heatsink.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        soldering 8 awg to 22 awg can prove to be tricky.
        the terminal block would be my suggestion.
        I don't believe they make reducers that go that extreme.
        I'm kinda surprised that the opus only has 22 awg wire to be honnest.
        no way to open it up and rejoin?
        an pics?
        Jan Bennett
          open what up and rejoin?
          Carputer Specs:
          Via M10K
          512mb Ram
          60GB HDD
          OPUS ITX PC Case
            the opus, if it's enclosed in a case
            Jan Bennett
              no its not an enclosed case, this is what the input cable looks like (obviously the 2 yellow are for power 2 black for ground red is remote turn on and blue is remote turn on for external units)
              Carputer Specs:
              Via M10K
              512mb Ram
              60GB HDD
              OPUS ITX PC Case
                so basically i have to connect the 2 yellow to 8ga and the 2 black to 8ga
                Carputer Specs:
                Via M10K
                512mb Ram
                60GB HDD
                OPUS ITX PC Case
                  Other than the strip like it sounds like you're using...I don't believe that there's a coupler that's made to go from 22 awg up to 8 awg.
                  you can try soldering them together, but I'm not sure how pretty it would be....lol
                  Jan Bennett
                    the one I have uses single 16 gauge wires
                    just to be safe add a fuse
                    Yev
                    R. T. F. M
                      lol! Cant i just connect them straight to a distro block?
                      Carputer Specs:
                      Via M10K
                      512mb Ram
                      60GB HDD
                      OPUS ITX PC Case
                        You can solder a ring connector to the larger (8 gauge wire) and and appropriate ring connector to the smaller wire and then use a small bolt and nut to connect them. When you are done run some heat shrink tube over them and you are set. One nice thing about this is that if you need to dismantle it later, you just need to cut open the heat shrink tubing and then unbolt them. I would reccomend a nylon insert lock nut to keep things from coming apart.
                        Another option would be a distribution block. You probably have more than one device which needs power anyway. Most local car stereo shops will have what you need. Most blocks are set to accomidate a certain input wire size, so don't get the one for 1/0 input.
                        Nick - 08 GG Element
                        Custom 3D-CAD Design, Reverse Engineering and Fabrication
                          yes, but since you said you didn't want the terminal strip I assumed you weren't interested in a distro block either.
                          besides, I don't reall a distro block that has 22 (or anything near that) to 8 awg.
                          Jan Bennett
                            I think this is what i am going to do!
                            Carputer Specs:
                            Via M10K
                            512mb Ram
                            60GB HDD
                            OPUS ITX PC Case
                              why are you using 8 gauge. thats too heavy. my opus150 has a 20a fuse in it. so i use 12 gauge
                              99.9% complete.
                              http://www.cardomain.com/ride/212327
