great car pc out of the box
  • great car pc out of the box
    this seems like a great caar pc for those to lazy to build it urself
    http://www.buy.com/prod/Enano_DVDRW_...202862036.html
    i think the core duo motherboard and processor alone cost like 600
    It looks good.
    The only thing that I can't find anywhere is the power requirement.
    It's more than likely an external power-brick type of connector, so it's very likley that a regulator like one of the Carnetix units (likely, the P1900) will work well for this setup.
    How about the Wiki?
      It does look good. I note the following:
      1) It's smaller than a single-din slot!
      2) It's DVI video, so you'd need a DVI to VGA adaptor to use most touchscreens
      3) All expansion must be via USB (not an issue for most)
      Nice find.
      KevPriest
        It does look nice, but the problem I have is what heppens when the motherboard dies? That is why it is nice though more of a hassle and expensive to build your own, though it seems no one wants to get into the market seriously besides VIA at the moment.
        My Install
          Nice find.
          KevPriest
          1) true
          2) true
          3) not true, check the mobo, they have serial and parallel ports connectios on the mobo, just not on the outside of the comp
          2004 Impreza WRX CarPC Install
          I am willing to host any legal downloads that may benefit the CarPC community - PM for info
          "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
          DG4L
            in terms of what?
            making mini-itx motherboards? or making mini-itx motherboards that have embedded processors?
            Jan Bennett
              Looks like a knock off Aopen mini pc
              http://minipc.aopen.com/Global/spec.htm
                Probably not a knock-off, but an OEM resale...
                  I don't care what it is, it is nice. Price is the only thing. But those who are willing to pay for a small setup, probably come to about 1/2 that price DIYing it. Add in advertising and profit, and it is not a total ripoff if you want a warranty, and don't want to build it yourself.
                  Nice find.
                  1.9in x 2.9in -- 47mm x 73mm
