help i want to put a bout 3 8'' screen multi vid split
  • help i want to put a bout 3 8'' screen multi vid split
    i have a 83 chevy c-10 and if yall guys and gals know the dash isnt that wide enough to put a big 12'' screen what i want to do since its a long skinny dash is to put 3 or 4 7'' or 8'' screen molded to the dash and connect them all to a single vid signal making it like a long screen i want to able to see the same vid or image split through the other screen it possible correct what would i need if had that idea for a while since right now i only have a single
    7'' and thats not cutting it for please dont kill my dream tell me it possible
    Yes it is possible. Basically you will need 4 video cards if you are wanting video, each with an output. Then use windows Extended Desktop onto it. The problem you will have is that windows doesn't like to play video on dual monitors let alone 4. If you have 2 monitors, it turns one half black, the other has video. There is an option to not let that happen but I forget what it it. Under Display Properties' advanced tab I believe.
    Oh, and for that, you better have a fast setup!
    1.9in x 2.9in -- 47mm x 73mm
      yeah, what 2k1 toaster said
      u can get a program called ultramon, its basically a program to control multiple screens, it might help you out as well
        sounds ok but thats it i need to be running a pc with 4 video cards
          Or get something like a PNY Quadro, there's one that has four outputs built into one PCI Xpress card.
            Surely 2x dual-head graphics cards would be cheaper?
              guys each DVI port has 2 channels, which you can split. so you would need 1 video card with 2 DVI outputs, and 2 DVI splitters.
              2002 Acura RSX CarPC Worklog
              Current CarPC Expenses
                just get an agp dual head and a pci dueal head. or get a matrox triple head and a PCI.
                there are those 4 outputs ones as mentioned but they are expensive and may not have the support you need as a regular consumer or support certain features in games, frontends etc you want as they are for graphics applications, CAD etc.
                You could even get usb2 grpahics cards but i would go pci and agp.
                there is a good multimonitor forum you could look at.
                for PCI ignore old S3 and the like cards and go with a more modern one as the old cards dont like being initialised after the AGP (bios setting) and ou have to set the bios to the pci 1st which isnt ideal for windows etc etc.
                  that depends on the card. some of the matrox yes but not old agp cards with DVI out. they are ust one screen per output on the back.
                    Try this great new product from Matrox :
                    http://www.matrox.com/mga/offhome/th2go/home.cfm
                    cheers.
