PCI bus Max?
  • PCI bus Max?
    Hello friends,
    I am considering purchasing a Via SP13000. It has 1 PCI slot. My question is am I going to max out the PCI bus if I get a riser card with two slots, and add an Audigy Z sound card and a TV/FM tuner card? Will I most likely experience slow, choppy performance from both cards?
    Or should I instead put the TV/FM tuner card in a single PCI riser, and use a lesser quality USB sound card?
    TIA
    No, you're not going to max out a thing.
    How about the Wiki?
      Via PCI slot supports 2 Masters PCI, so you're fine with a dual pci riser
      Now Galileo is real. Muhahahahaha :p
