ATX Power On
  • ATX Power On
    How do you all power your ATX motherboards automagically everytime?
    I have no "Startup automatically after power loss", shorting pins 13/14 or permanently shorting the "Power On" cable only creates a reboot loop. I ran phone cable from my dash where the buttons are to the Power On jumper on the mobo, and it couldn't get a signal. I may need a battery in there to boost the signal. I'm out of ideas and couldn't turn up anything in a search. Any ideas?
    Don't Click
    Re: ATX Power On
    hrm... extending the wires worked for me..... and I cant see why it would not work for you.... unless the wire you used had a REALLY high resistance.....
    I dont need it anymore since I have the 'after power loss' option in my BIOS......
    Project - GAME OVER :(
      A small timer circuit and a small relay can be used to "bump" the power switch after power on. Check some of the datasheets or application books for the 555 timer.
        I had used 4 wire phone cable which must have had higher resistance than I thought. I switched to stranded speaker cable and now it works perfectly.
        Don't Click
          good for you! always run a bunch more cables than you need!
          bunch<- learn to spell
          My cars
