power switch, can it be by-passed
  • power switch, can it be by-passed
    is there a way to get the laptop, or a laptop for that matter. to come on when power is plugged in, Im guessing its a atx type of switch so I cant hard wire it to alway stay on. basicly if I turn off the car I have to hit the power button when turnning it back on. that is if the laptop battery is dead, and it didnt hold a chage. any thought ideas.
    UMPC built in to dash.
    Winamp, game emulators, Touchpad built in to car, DVD player built in to dash, GPS gamrmin moble pc. IR remote for use of a remote control. ps2 supper mini keyboard for when needed.
    if its a switch... it can be bypassed
    2001 PT Cruiser "BLK ICE"
    http://www.cobaltcarpc.com
      hmmmmm
      hmmm, guess yor right, to the scamitics we go.
        you just want it to automatically come on when you start your car?
        just get a relay, hook up one wire from the power switch on the laptop to one of the sides of the relay and then hook the other wire to the other side, hook up a ground wire also to the grounding terminal. then for the final connection run a wire from keyed power (off the fuse panel is the easiest way) to the trigger on the relay. that way whenever u turn the ignition on it'll trip the relay and then the mobo will think u have just pressed the button seen as most power buttons are momentary switches.
        [edit]
        hrm...maybe that made no sense to your setup!
        uhm...how is it hooked up in the car?
        writing c++ crap for the past 6 hours fries one's brain
        [/edit]
        1997 Jeep Wrangler Rugged Waves
        Ebay Stuff For Sale
          ok
          well I dont know what a mobo is but your answer is basicly what I will attemp. I have a laptop basicly with a atx type of switch, one press its on, 6 second press its off. butIm only worried about the on function. So I wont need a curit to stay on for 6 second. bacily the relay would do the trick, but Im trying not to have to open the laptop again. but that may be the only way.
            yeah i see what u r doing now!
            hehe
            you will have to open up the laptop and just hard wire in some wires from a relay to the switch circuit, but the idea i stated would do the trick i'm pretty sure
            Ebay Stuff For Sale
              agreed..
                Before you open your laptop again and risk killing some kittens try this:
                http://www.mp3car.com/vbulletin/show...8283#post48283
                Might or might not work for you. Seems like your laptop works somehow differently but it's worth trying.
                  Re: ok
                  Mobo - Motherboard - MB
                  And you say people actually pay money for M$ Windows?
                  www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
                  Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
                    hmmmm
                    good point. never though of it. the bios may support it. thanx
                    and mobo=mother boards duh. ok thanx angain.
