Compact Flash or Hard drive booting
  • Compact Flash or Hard drive booting
    Hi,
    I am going to build a car PC and wanted to know how much quicker a CF card will boot XP than a hard disk, roughly speaking, as none of the posts seem to mention speed difference.
    My first car PC was a Pentium 233 which I built 5 years ago. It was purely an mp3 player and used a DOS mp3 player, 10Gb hard drive, custom keypad and a dot matrix display. It only took 6 seconds to boot from cold to hearing music, which isn't too bad considering the processor speed and old hard drive.
    One more question. If I were to 'ghost' a working version of XP onto a Compact Flash card, could I make it read-only and use the hard drive for the swap files etc.? and would it still be possible to install things onto the computer, eg. plugging external drives in to update mp3s and possibly installing programs onto the machine?
    Thanks in advance for your replies
    Craig
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    That's because there is very little, if any speed difference when booting from a CF card.
    The primary reason fro booting from a CF card or some other flash memory is to allow the system to boot despite a harsh environment, namely extreme cold that would congeal the fluid surrounding bearings, causing the drive not to spin up until it warms up a bit.
    And no, the Ghost image to a CF card isn't going to work, at least not for very long. CF cards have a limited number of write cycles. Since windows is going to write to the boot partition repeatedly during the course of normal use, you're going to exceed the write cycle limitation in short order.
    There is a guide to preparing a Windows installation for a CF card so that it doesn't need to write. I don't know what all is involved, because that's nothing I'm doing for my project.
    How about the Wiki?
      Thanks for the reply. I understand that the read/write to a compact flash will eventually burn the card out and this could happen in a matter of months. But is there a way of installing XP to a compact flash and making it read-only and using the laptop hard drive for the normal Windows XP scratch disk?
      I have looked but cannot find any tutorials etc. here about putting XP on a card, could someone post me a link.
      Thanks again
      7" Lilliput
      120Gb Sata drive
      1GB RAM
      (Always tweaking!)
        http://www.mp3car.com/vbulletin/show...hlight=compact
        Search is your friend!
        Jan Bennett
          check here: http://osf1.gmu.edu/~sfiorito/eXPinstall.htm
          and the WinNT forum. search for EWF.
          EWF, HORM, MinLogon on XP.
          Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
          Win Embedded Std 2011 RC
          OCZ Vertex Turbo 30GB SSD
          Lilliput 629 Transflective, WRX Screen Mount
          BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
          VoomPC 2
            SFiorito, A genius....
            I read a massive post which you and a few others were talking about putting XP on a flash card, and now with the link you gave me, everything seems possible.
            7" Lilliput
            120Gb Sata drive
            1GB RAM
            (Always tweaking!)
