Does the Aopen i945GTt come with a power brick?
  • Does the Aopen i945GTt come with a power brick?
    Hi All,
    I'm working on v2 of my carPC and just ordered the Aopen i945GTt. I'm also looking to use the P1900 with it. I'm curious what type of power connector (brick?) this mobo comes with? Anyone have a pic? Will I then need to splice the P1900 into that?
    TIA,
    Per
    bump.
      It comes with a power brick. All you need to hook it up to the p1900 is a 2.5mm x 5.5 dc barrel connector
        Isn't the p1900 a full power supply? Can't you just use a startup/shutdown controller? if not.. why?
        Thanks,
        Chris
        2004 Ford Mustang Mach 1
        Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
        Install Status: DONE
        My XM FAQ
