Help with motherboard and power supplies
  • Help with motherboard and power supplies
    I have considered 2 options for the basis of my carpc system;
    Option 1
    Jetway J7F2 1.5GHz C7 Mainboard
    • VIA C7 1.5Ghz Processor
    • VIA CN700 + 8237RP
    • Front Side Bus: 133MHz
    • Graphic Interface: integrated 128bit 2D/3D VIA S3 Graphics UniChrome Pro Processor
    • 1 x 240-pin DDR2 Module Sockets Support Max 1GB - Unbuffered non-ECC memory required.
    • Audio: Onboard 6-Channel CODEC Compliant to AC 97'
    • On Board 1394a Port
    • USB: 2 USB ports + 6 x Internal USB 2.0 headers
    • Serial ATA: 2 SATA connectors
    • IDE: 2 x ATA 133 IDE connectors
    • TV-out (PAL / NTSC): VIA VT1622A TV encoder
    • Expansion Slot: 1xPCI Slot (PCI 2.2)
    • VT6103 10/100 Ethernet
    • 1 x Optional add-on board can be fitted.
    • Dimensions : 170x170mm
    • RoHS compliant
    Obviously I will need to add RAM, hard disk, wireless and optical drive and peripherals. What power supply unit would you recommend?
    Option 2
    Maxdata Intel Celeron D 3.06Ghz 512MB DDR 80GB SATA DVD-RW 16x Dual Layer,7in1 Card Reader
    • Intel Celeron D 3.06Ghz Processor
    • 512MB Memory
    • 80GB SATA II Hard Drive 7200RPM
    • DVD-RW 16x Dual Layer Optical Drive
    • 7in1 Card Reader+Floppy Disc Drive
    • VGA Onboard
    • Dimension:180 (W) x 360 (H) x 420 (D) mm
    • Operating System- DR-DOS 7.0
    • Nero Express 6
    • Norton Anti-Virus 2006 (90 day trial)
    • Power DVD 6
    • On Board 10/100 LAN
    • UK Black Keyboard - Cherry
    • Optical Mouse
    Ports
    • 2 x PATA Ports
    • 4 x SATA Ports
    • PCI Slots: 3 x PCI,
    • 64MB Maximum Onboard VGA Memory
    • 10/100 Onboard LAN
    • 1 x Serial Ports
    • 1 x Parallel Ports
    • 2 x USB2 Ports Front
    • 4 x USB2 Ports Rear
    • 2 x PS2 Ports
    • Dimension: 190 (W) x 360 (H) x 375 (D
    • Average Weight: 12KG
    With this option I will only need to add the power supply unit and peripherals. What power supply unit would you recommend for this setup?
    * A specific carpc case would be used for option 1 and a custom made small form factor case would be used for option 2 *
    http://store.mp3car.com/SearchResults.asp?Cat=22
    http://www.mp3car.com/vbulletin/showthread.php?t=88875
      better yet....
      Link directly to the FAQ: http://www.mp3car.com/vbulletin/showthread.php?t=68636
      Although Chris Hare's CPU electrical specs don't list the C7 CPU. I asked him about it, and he doersn't intend on listing anymore Via C-series CPUs, as they are, in his eyes, more geared toward standalone devices.
      I didn't debate that with him, since he's the one taking the time and effort to provide the good resource in the first place.
      How about the Wiki?
        Thanks for your help; ive gone one step forward in one area and one step back in another. Watch this space..
