Using a solder iron to make holes in plexi/lexan?
  • Using a solder iron to make holes in plexi/lexan?
    I saw a couple messages on people using their solder iron to make holes for the ports in their plastic cases. How exactly is this done? I'd rather have the info before I attempt to vaporize plastic and set the whole damn thing on fire. Yeah I've heard you can use a dremel but they're expensive.
    I've tried works but its very slow unless you have a high powered soldering iron...I have a 30W and it was taking me forever to get through my .25" thick acrylic. Also, walmart has dremels (actualy brand-name dremel tools) for $34 if you think that is too expensive
    Dremels work well too...I would never use one for precision cutting make fan holes, I use a 76mm hole attachment for my drill, and to cut the acrylic i'd use a saw.
      Re: Using a solder iron to make holes in plexi/lexan?
      it shouldnt catch on fire, just have a well ventilated work area since the fumes will stink alot!!! also give your soldering iron tip a really good clean afterwards..... burnt plastic on a soldering iron wont do too good...
      Project - GAME OVER :(
        I tried it today and it just turned into a gooey mess . there's no way to cut straight lines without major hours of effort. oh well guess i'll have to just drill circles for the ports.
          I'm creating now my plexi case and I'm using a 1 cm attachment for my drill and a dremel like attachment to correct later-on little mistakes. I first practiced cutting 3 holes for a lpt port in a spare piece of plexi just to make sure I'll do it right when it will be in the real box.
          Status: I still need to get some money to buy the inverter.
