Boot from CF in MII12000 ???
  • Boot from CF in MII12000 ???
    Hi, i am spanish....
    Mi hd is died...
    Can I boot from a CF placed in the cfslot of a MII12000 ????
    I want to use a 4g CF to boot and a HD-USB to place the music....
    Thanks..
    Sorry for my english..
    no, the CF slot on the MII is not connected to IDE. There are ways to boot Linux, but not Windows.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      unless you get a CF adapter
      why not just buy a new HD, they can be had super cheap
      Jan Bennett
        Ok... so i will use only the HD-USB... in the bios sais that i can boot from it.
        Thanks....
        Edit:
        Ummm ... anybody have tried it ????? Is this posible ????
          yes, technically it can be done but most likely it'll be more work than you're willing to do and it'll be very slow because the MII uses the Award BIOS which makes the USB ports run only in USB1 speeds.
          Just get a new HDD.
          VoomPC 2
