gps help.
  • gps help.
    Hi i have a MiTAC gps unit (based on SiRFStar chipset) i think my firmware needs to be updated, because my comp is set to todays date and the gps info says its september something 1997. however the time is correct, any one have the firmware? this unit was also sold under the name "PORT Metro Guide". thanks
    mp4runner.com
    I had one of those....your best bet is to chuck it out the window.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
      thanks. i thought that was going to be my only option.
      mp4runner.com
        Check inside for a dead battery. My GPS (not the same as yours) has a lithium cmos-type battery inside to retain the time and position when the power is off.
        (=========-) 99% complete
        AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
        All jammed in external CDROM drive case.
        Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
          hmmm sounds probable, but the thing looses satellites when trees are on the side of the road (unit is on my roof) also takes at least 10-20 minutes to get a fix.
          mp4runner.com
