what kind of material to use
  • what kind of material to use
    Ok people,
    I'm looking for a material which WILL bend but "wants" to be straight... I don't think I'm making any sence, but I don't know how to explain in english....
    look at this ani:
    the black line represents the material I'm looking for and is attached to the blue blok. the blue block moves back and forward making the material slide in and out. This material needs to be stiff enough to push up my 12.1" TFT, but also needs to be "bendable" enough to make the tight turn....
    any ideas??
    thanx,
    Marsjell
    ohw btw I was thinking of using a strip of some kind of fiber material, any idea if this will work, or where to get it?
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
    Re: what kind of material to use
    well, that was a hard one... if you are handy with the tools, try to make a carport like design
    have 2 rails and the carport between them....
    i would go for some kind of wire, but thats more to pull than push...meabye a bicycle chain involved?
    try to make a pic where i/we can see where the screen goes
    My cars
      the screen will go on the side of the blackline, where the blue box isn't connected.
      A chain won't work as it wil "rippleup" also, it needs to be as thin as possible... well 2 or 3 mm won't matter, but 6 or 7 is too much.
        Take apart some power antennas and use the plastic strip...
        Or, most RX-7s came with sunroofs. Find one in a wreckers and remove the metal bead line used to actuate the roof. That stuff is exactly what you want.
          thanx, I'll look into that....
            well how about spring steel, such as from an tape measure?
            NOTE:
            not saying to use a tape measure cause that material is in a U shape when viewed from cross section, but spring steel such as in constant force springs. You can get it from www.smallparts.com or mcmaster.com
            Justin Stiltner
            Truck :1993 Ford Ranger Splash 4.0L
            System : Pioneer HU and Factory replacement speakers
            Puter :Pentium OCed to 133Mhz and win 95 with a whistler power inverter and crystalfontz 20x4 lcd(soon to be motorized) and winamp
            Comms Gear: Cobra 25WXST, K40 whip, Silver Streak 175, Radioshack Hyperscan Pro-2045
            95 Mitsubishi Eclipse RS: FOR SALE!!! $4000
            95 Egeal Talon Tsi AWD: Project car boostin 15 psi.
