WinTV PVR 2 USB "graph cannot connect" problem. HELP!
  • WinTV PVR 2 USB "graph cannot connect" problem. HELP!
    Hello,
    I'm not sure if this is the deserving forum, but since it's dealing with my hardware device, I figured to post here.
    I have Hauppauge's WinTV PVR2 device. I've downloaded the WINAMP WINTV plugin. When I try to configure the plugin, I immediately receive the error:
    Graph cannot connect.
    Error: No combination of intermediate filters could be found to make the connection.(80040217)
    Capture driver: Hauppauge WinTV PVR2 USB2 Encoder
    Any help would be greatly appreciated!
    Have the same issue, did you ever get a resolution?
      same error
      Same here with an usb DVB-T card... :-( I'm going mad
      My new dash setup with 8.4" LCD!
      Secondary (roof) LCD display
      False floor with mobo, amp and all the electronics
      Power supply and HDD Suspension system detail
