Video driver problem
  • Video driver problem
    Hi,
    I am trying to troubleshoot driver problems with my carputer...
    I am running WinXP SP2 and the following MB
    http://store.mp3car.com/ProductDetai...Code=MTB%2D014
    Problem description:
    when the drivers (either from the cd or downloaded from VIA) I am losing video signal from my computer upon it trying to login. It does go through the boot screen and I can get into safe mode. If I remove the video device from Device Manager, it boots up *correctly*.
    I figure it must be some kind of driver conflict -- just not sure how to figure that out. The computer had been running fine for the last week or so... And the only thing I have been working on is getting bluetooth working. Bluetooth drivers were finally correctly installed last night and everything continued to work ok. This morning is when I first ran into the issue.
    Any Suggestion?
    Nasa
    Actually it sounds like your display resolution is set too high for the monitor you're using. Got another monitor you can plug in?
      Yeah,
      I am running my carputer on my bench right now, and yes the same things happen. Thanks for the suggestion, though.
      Nasa
        Seems Other people have been having this issue:
        http://forums.viaarena.com/messagevi...&enterthread=y
        nasa
          tried booting in Safe Mode?
          Greg
            GregDro
            (see 1st post)
            Thanks for looking.
            Nasa
            BTW: I'll take any suggestions I can get....
              I had this MB before and I had accidently selected TV as an output in the BIOS and it did this same thing. Have you tried to hook up a tv to see if the output is switching to it. Just a suggestion.
              The Car 2005 Scion xB
              The Truck 2004 GMC Canyon
                Thanks for all the suggestions guys,
                I talked to tech support and have RMA's the board. Let's see what they have to say about it!
                Nasa
                  Follow up?
                  New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
                  SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
                    masch:
                    It was a bad board. MP3Car swapped it out for me... I have since gotten rid of that board (more trouble than it's worth) and now working with a Duo Core MB.
                    Nasa
