Filling Holes?
  • Filling Holes?
    While probably not quite a "hardware" question, I figured that as its a result of hardware, this is probably the best place. In the continual refining and tweaking that we all do to our systems, I came up with a much cleaner way to integrate the power controls for my computer/inverter into my car. The problem being that I drilled a .5" hole into the plastic below my current remote. Does anyone know of a "plug" for the hole? something that would sit on top of the hole, hiding it to some degree? and where I might find it? The mental picture in my head would be something along the lines of the caps you put over the screws in woodwork.
    Get a piece of clear lexan, cut it to shape, then paint the back. The result is a "black mirror" effect. May or may not be what you are looking for...
      It's called JB Weld and fine-grit sandpaper
      overall status software: ~40% completed, hardware: ~80% completed
      computer 10GB laptop drive, 192MB RAM, Intel MU440EX Motherboard, Celeron 300, 10/100 NIC, Windows 98SE, FM brodcaster from Radio Shack (12-2051A), 1U 200w ATX power supply, Sproggy 2.6 PSU, ATX Shutdown Controller, Crystalfontz 2x20 LCD (CFAH2002A-YMI-JPV), plexiglass case
      car 1995 Mitsubishi Eclipse GS. 4 cylinder, 2.0 Liter, DOHC
