Asrock K7NF2-Raid Socket-A experiences?
  • Asrock K7NF2-Raid Socket-A experiences?
    I've search the forums but cant find any mention of this board. It seems to have everything I want with ability to under clock for the Athlon xp mobile 2400+ I've got but can't find anywhere that says it has S3 power save mode. Any body have any experience of this board or knows whether it has S3?
    the board is
    Asrock K7NF2-Raid Socket-A Motherboard
    CPU - Socket A (462) for AMD Athlon XP/Athlon/Duron/Sempron™
    - FSB 400/333/266/200 MHz
    - Northbridge: nVidia nForce2 Ultra 400
    - Southbridge: nVidia MCP-RAID
    Memory - Supports Dual Channel DDR400/333/266
    - DIMM slots: 3
    - Max. capacity: 3GB
    Hybrid Booster
    - CPU Frequency Stepless control
    - CPU Multiplier
    - CPU Vcore Adjustment
    - AGP/PCI frequency fix
    - ASRock U-COP
    - Boot Failure Guard (B.F.G)
    BIOS Feature
    - 4Mb AMI BIOS with ACPI, SM BIOS 3.0, PnP
    Hardware Monitor
    - CPU Temperature Sensing
    - Motherboard Temperature Sensing
    - CPU Fan Tachometer
    - Chassis Fan Tachometer
    - Voltage Monitoring: +12V, +5V, +3.3V, Vcore
    Accessories - Quick Installation Guide, Support CD, I/O shield
    - Floppy/ATA 133 cables
    - 1 x SATA data cable
    - 1 x SATA 1-to-1 power cable
    Form Factor
    - ATX, 305mm X 198mm
    Have you looked in the manual?
    (Hint: It's on page 27)
    How about the Wiki?
      Just found the manual which talks about suspend to ram. Is this S3 power saving?
      Thanks DarquePervert
