Bluetooth Problem
  • Bluetooth Problem
    So i was having problems with my carpc. The pc kept crashing with a bluescreen of death and restarting. When i went into checking the issue, which i thought was hardware. I found out that the Bluetooth software was the problem of the crashing. So i disabled it. Anyone got an idea of a bluetooth update for windows 7? Should i update it and see what happens?
    I would look into a bluetooth stack from the manufacturer that is compatible w/ Win7 specifically.
    If you're running a manufacturer-supplied BT stack, you might consider removing that and using Windows' built-in BT stack.
    How about the Wiki?
