Known Bugs and Fixes as of 27/08/07
  • Known Bugs and Fixes as of 27/08/07
    Ok, this being the first revision, there are some goofs. Nothing very important, but "quirks". Below is a list of all the known bugs, goofs, and quirks, and what we are doing, have done, or will do.
    Output Pins do not match [HL]KNOWN AND FIXED ON VERSION 4[/HL]
    This was an error in PCB layout where the outputs are just not in the correct order. The LED's are, in the correct sequence however. This is no way degrades the basic functionality of the unit. The errors are all superficial.
    For the Digital Outputs: [HL]KNOWN AND FIXED ON VERSION 4[/HL]
    For the Analogue Inputs: [HL]FIXED[/HL]
    Accelerometers don't work well or at all: [HL]FIXED[/HL]
    This is due to a miscommunication with our manufacturer, and they installed a 3.3volt part when we wanted a 5 volt part. We will offer cables that have integrated voltage regulators. As of now, DO NOT CONNECT YOUR ACCELEROMETER TO THE FUSION BRAIN. You can either wait for us to assemble an mail you a cable with a built in voltage regulator, or you can contact us, and we will provide you with part numbers for popular websites and stores where you can buy this small component and fix the problem yourself. It is an easy job, and required 3 solder points. We will be providing cables at no cost, but if you need this right away, we can help you expedite it.
    Analogue #0 does not work correctly [HL]FIXED[/HL]
    FIXED AS OF JULY 7th 2007
    This is currently a firmware problem. In our haste to fill pre-orders, we failed to find a flaw in the current firmware that prevents Analogue #0 from being read. The good news is that it is a firmware problem (software for the microprocessor), and not a hardware problem. That means we can reflash or reprogram the big black chip on the board, and as soon as it is pushed back in, it will work correctly. We are currently fixing the firmware, and we will provide an upgrade program for free. There will be 2 options. Option #1, is that you PayPal us $9 as a holding fee, and we will immediately ship you out a new chip. Replace your current chip with the new one, and mail us back the old chip in the prepaid return envelope, and as soon as we receive the chip, we will refund you the entire $9. Option #2, is that you send us back the chip, and once we receive it, we will send you a new chip. This will render your Fusion Brain useless until the new chip arrives, but does not require a $9 holding fee.
    When a sensor is connected, unused ports show activity as well [HL]NOT A PROBLEM[/HL]
    The solution to this is to just put a jumper from Ground to the Voltage Input on the unused inputs. In the software however, if you are not using an input, do not configure it in the skin setting.
    1.9in x 2.9in -- 47mm x 73mm
    The analogue inputs have been fixed on all current firmwares and an upgrade program is in effect as well. Details are above.
    The digital outputs we have a small fixer board coming to us now and we should be able to mail them out within the month.
    Acceleromters should be shipped out within the month. This is not definate though because as of today they are lost over the Pacific Ocean somewhere... I hope they show up on land again in a few days though and then the patching can begin!
    Analogue #0 has been fixed in all firmwares, and the upgrade program is above.
      Can you post instructions on how to fix this?
        We sent an email to everyone around late December 2007 with information for the free accelerometer exchange if you ordered. We have a new version that does work and is what we sell, so that post is no longer valid.
          I know it says the Digital outputs have been fixed, but the Brain Im playing with (shipped Sept 2008)still has mismatched pins to ports, and not in the same way as the table above:
          Port Pin
          0 7
          1 4
          2 5
          3 3
          4 0
          5 1
          6 2
          7 6
          8 8
          9 9
          10 10
          11 11
          Sorry, I can't do fancy tables. This presumes both pins and ports start with 0, with 11 being closest to the power connector. The LED patterns match the table above though.
          So, for example, if I tell the brain to trigger a relay on Port 7, it will flash LED 4 and turn on pin 0.
          http://sticksout.blogspot.com
            Yep mine shipped in November here and I have the mismatched pins as well.
              All Version 3's have mismatched pins. Version 4 will not.
