Problem purchasing Fusion Brain
  • Problem purchasing Fusion Brain
    my browser is creating an error message saying the security certificate for the fusion brain website is using was acctually issued to different site. "*.sslpowered.com" out of toronto canada.
    I'm not verified with paypal so that site won't let me use it, and i'm sketched out enough about the error msg to hold off on using my card
    anyone else get this error message?
    Toronto Canada?! That is odd... Probably where our host is located.
    Are you using IE, or FF?
    I can tell you not to be sketched out, just accept the certificate and try it.
    ".sslpowered.com" is the secure part of the website. The actual website where you add stuff to your cart, is not secure. The part where you checkout is secure. They are hosted on 2 servers. So certificates see them as 2 websites even though they are the same. That is about the best explanation I can give...
    If you use the PayPal Express checkout, it will all be done through PayPal directly if you are more comfortable that way. If you use the regular PayPal checkout, it is intercepted by our website, we process it add it to the queue, and then forward to PayPal for payment. If you use Express checkout, it will take longer for a confirmation because it goes from the site to PayPal and we have to manually verify payment and add your order to the website.
    1.9in x 2.9in -- 47mm x 73mm
      i just went on using firefox instead and it worked fine, IE's always a little twitchy. can't wait to get the part
        I test everything using FF and then I try as much as I can with IE6 or IE7, but I develop for FF.
        Glad it worked, and you should get to play with it soon!
