a couple of questions
  • a couple of questions
    Hey all,
    1. I wanted to know how hard it is to control my air ride from my pc?
    2. also what would happens if the computer, one day, decides to die... can I use a Dakota digital stabelizer?
    3. What's the reponse time between adjustment and action??
    thanks
    steve
    My Car!
    1. It's not hard at all. Like I said in another thread, I'm in the process of writing up a tutorial.
    2. If the computer dies, you can use whatever is compatible with your sensors and solenoids.
    3. The response time is can be tuned as low as 2mS, although this is extreme overkill. Typical timer values are set around 100mS. (millisecond - 1000mS is one second)
      Can I also use this for reverse camera input to my PC?
      How many output and inputs are there?
      My Car!
        Greenman 100 send me a message at dasaint80 on AIM.
        My Car!
          You can use it to turn on a camera, but it does not handle video processing... that's quite a job.
          There are 12 outputs, 10 analog inputs, 4 digital inputs.
            I tried, you weren't online. My s/n is greenman100
