Steering Wheel Control Help
This topic is closed.
  • Steering Wheel Control Help
    I'm a little confused on hooking up my steering wheel controls.
    Car is a 2006 350z.
    Steering wheel controls are 2-Wire Resistive type.
    Pin 16
    Power (Press and hold POWER switch.) Approx. 0Ω
    Seek down (Press and hold SEEK DOWN switch.) Approx. 165Ω
    Volume down (Press and hold VOLUME DOWN switch.) Approx. 652Ω
    Pin 20
    Mode Press and hold MODE switch. Approx. 0Ω
    Seek up (Press and hold SEEK UP switch.) Approx. 165Ω
    Volume up (Press and hold VOLUME UP switch.) Approx. 652Ω
    How should I hook this up? Please in laymen terms.
    What were you measuring? Pin 16 to ground? and Pin 20 to ground?
      Straight from the service manual.. Thanks mate
        Nice! I can help but I'm not home right now. I will in the next day or two, rest assured.
        you'll need two resistors, that's it. I'll post info later
          Much appreciated mated. My installer just gave me a blank stare when I handed him my CarPC and Fusion brain..
            read this:
            http://www.mp3car.com/vbulletin/docu...-controls.html
            apply solution D twice
              Thanks. I have read that thread but I don't get the wording.
              And your steering wheel is R2. Connect one steering wheel wire to ground, and the other the steering wheel wire to the input of the brain and one side of R2. Connect the other side of R2 to the +5vDC pin on the brain's analog input header (towards the center of the board). You're done!
              So one steering wheel wire goes the Fusion Brain ground (does it matter which?)
              Then the other goes to the brain analog input and R2? I'm connecting one wire to two places?
                Look at your service manual. Pin 17 is shared by the two steering wheel controls... is it has to be ground.
                Pin 17 to ground
                Pin 16 to FB input and R1
                Pin 20 to FB input and another R1
                tie the other sides of both R1s to +5vDC on the FB.
                make sense?
                  EDIT: I'll give you $20 for a retard friendly diagram. lol
                    I just fixed the wording in that other thread.
                    i'll whip up a drawing, h/o
                      Pin 17 to ground
                      make sense?
                      I think I get it now.. Can pin 17 be any ground or have to ground on the FB?
                      So splice Pin 16 two ways. Same with 20. Tie both R1's together and back to +5 on FB.
                      I get it..
                        not quite "professional" quality, but it was fast
                        let me know if you have any questions. it can be any ground, but it's best to run it back to the brain. Technically there's no difference, but if you ground it to a crappy or dirty point it can cause issues
                          Your MS Paint skills amaze me.. lol
                          Seriosully though, appreciate it mate. Makes perfect sense now. This was a must have for me as I love my steering wheel controls.
                          EDIT: Anything AROUND 660 for the resistor should be fine right? It does say Approx.
                            yup, like 500-800 would be fine
                            all it will change is the output voltage slightly... which won't matter because the correct next step is to hook everything up, push a button, record the voltage, push a button, record the voltage, etc.... if that makes sense
                            the only reason it'd have to be exactly a certain resistance is if you had to calculate the theoretical output voltage... but you can measure it, so no worries
                              Makes perfect sense.
                              The FB can record voltage itself right? I don't have to measure it manually and then tell the FB the voltage for each button?
