Recording sensor data.....
  • Recording sensor data.....
    Is it possible to use the FB and it's attached sensors as a data-gathering tool?
    The AutoAC system I have mentally visualized will rely heavily on an empirical model derived directly from thermodynamic data gathered in the vehicle.
    In order to do that, I will need a fairly large data set, with points at various blower speeds and door positions under varying exterior and interior conditions (temperature and possibly humidity).
    Is there a way to easily implement a sort of data-gathering mode that outputs all current sensor values to some kind of spreadsheet, Excel maybe or a CVS? Or will it be necessary to devise some kind of script that takes care of that for me
    2007 F-250 Crew Cab Harley Davidson - optioned out
    Plans:
    Completely blacked out exterior
    Second Skin dampening
    3-way active front stage
    Full PC processing
    2 JL 13TW5 subs behind rear seat
    Completely stealth install
    http://www.mp3car.com/vbulletin/fusi...g-example.html
      I guess I should learn to scroll down rather than just searching
      Plans:
      Full PC processing
