HOw to hook up an input to the FB
  • HOw to hook up an input to the FB
    OK so I can't quite figure out how to physically hook up an input to the FB. I'm trying to hook up my steering wheeel controls and I have them all ready to hook up (used a voltage divider and one wire outputs signals below 5v).
    I can't find a diagram that shows the FB and where each wire goes. Do I need to hook up to the red wire poles? How do I do this?
    [||||||----] - 60% Complete
    http://www.mp3car.com/vbulletin/docu...er-manual.html
    right there in documentation
      exactly what i was lookin for thank you
        I'm still not sure on how to hook up the wire. Does it run across all three of the analog input prongs or does it just need to touch one of them?
          Since you have your own power and ground already, you only need to use 1 wire. The 1 wire from your steering wheel controls onto the Input Pin of an analogue input. The +5v and GND on the Fusion Brain are meant to power sensors and such.
          Also since you are doing steering wheel controls, you are probably the first guinae pig I have for the new dTime feature in MDX added 5 days ago. This way you can set how rapidly the buttons fire the software and the new imporved key sender as of last night too. Let us know how you do.
          1.9in x 2.9in -- 47mm x 73mm
            Awesome, I think I got it figured out I'll let ya know how it goes.
              i'm having a problem getting my computer to recognize the FB. Everytime I plug in the FB the install new hardware wizard comes up. If I try to install it automatically it says windows can't do it. I try to install from a specific location but I can't find the right place. The files in the driver folder dont show up when I try linking to them. Anyone know what Im doing wrong. I'm running XP
                OK got the drivers installed now just trying to get the SWC setup
                  OK, how do I know if I have the SWC wire hooked up correctly and if the FB is reading it or whatever.
                    I think I'm starting to understand how to hook up the wire. It looks like with the analog input, each of the 10 inputs has 3 prongs. Do I need to hook up anything to the 5v dc pins and the ground pins or do I just hook the wire up to the last pin, the input pin?
                      Code:
                        <general>
                          <debug status="on">
                            <virtual_brain id="mainbrain"></virtual_brain>
                          </debug>
                        </general>
                      Put that under main root so it is in the same level as "<require>", "<graphics>", "<io>" and "<logic>" the FusionConfiguration.xml
                      Change "mainbrain" to the ID that you are using on your fusion brain isntance.
                      This will bring up the debug window that shows all inputs, all outputs and everything. Then you can see if the wire is in correctly. Also make sure that your analogue input has autoaveraging turned off for steering wheel controls.
                      And as I said in my earlier post, no you dont need all 3 wires since you are not using a sensor that needs power
                        I've tried putting in the code but nothing happens. I even edited the xml file, added the text and saved it. But, when I open fusion configuration program the text does not show up.
                        Also I'm trying to create key presses using the FB software but I'm a little confused. I've been looking at this for a guide but I'm not quite sure if I'm doing it right.
                        I've created the brain instance and an analogue input instance. But, I'm not sure if I have set it to read from the right pin/input #. I believe the one I am using is #8 but I might be wrong This is how I have it connected
                        0 0 0 0 0 0 0 0 0 0
                        0 0 0 0 0 0 0 0 0 0
                        0 0 0 0 0 0 0 0 0 X
                        I am connected to the X input last one on the end of the board. The input is labeled 8 on the board but I'm not sure if it has a specific pin #.
                          please upload your xml file
                            <?xml version="1.0" encoding="utf-8" ?>
                            - <FusionControlCentreConfiguration version="3.0.0.0" author="Me" date_created="Tuesday, June 10, 2008 at 7:59:29 PM" last_modified="Wednesday, June 11, 2008 at 11:14:25 AM">
                            - <require>
                            - <!-- Begin Function Instances
                            - <!-- End Function Instances
                            - <!-- Begin Fusion Font Instances
                            - <!-- End Fusion Font Instances
                            </require>
                            - <graphics>
                            - <!-- Begin Global Graphic Settings
                            <main_display designed_for_size="800,600" show_at_size="800,600" menubar="Sizeable" RunInSystemTray="False" MinimizeToSystemTray="True" />
                            - <!-- End Global Graphic Settings
                            - <!-- Begin Background Images
                            - <!-- End Background Images
                            - <!-- Begin Static Images
                            - <!-- End Static Images
                            - <!-- Begin Variable Location Images
                            - <!-- End Variable Location Images
                            - <!-- Begin Graph Instances
                            - <!-- End Graph Instances
                            - <!-- Begin Display Buttons
                            - <!-- End Display Buttons
                            - <!-- Begin Multi Images
                            - <!-- Begin Text Labels
                            - <!-- End Text Labels
                            </graphics>
                            - <general>
                            - <debug status="on">
                            <virtual_brain id="Grand Prix Brain" />
                            </debug>
                            </general>
                            - <io>
                            - <!-- Begin Fusion Brain Instances
                            <brain id="Grand Prix Brain">usb\vid_04d8&pid_000c\6&3ab92d65&0&4</brain>
                            - <!-- End Fusion Brain Instances
                            - <!-- Begin Timer Setup
                            <timer id="input" interval="75" />
                            <timer id="output" interval="100" />
                            <timer id="gui" interval="50" />
                            <timer id="logic" interval="50" />
                            - <!-- End Timer Setup
                            - <!-- Begin Digital Output Instances
                            - <!-- End Digital Output Instances
                            - <!-- Begin Analogue Input Instances
                            - <iochannel id="Steering Wheel Controls" port="8" brain="grand prix brain" type="analogue_input">
                            <options history="0" auto_average="false" />
                            </iochannel>
                            - <!-- End Analogue Input Instances
                            </io>
                            - <logic>
                            - <!-- Begin Logging Setup
                            <all_logging />
                            - <!-- End Logging Setup
                            - <!-- Begin Variable Declarations
                            <all_variables />
                            - <!-- End Variable Declarations
                            - <!-- Begin Logic Declarations
                            - <all_statements>
                            - <if fire_on="logic" minimum_delta_vote_time="1000">
                            - <boolean_operation type="greater than or equal to">
                            - <parameter1>
                            <analogue id="Steering Wheel Controls" time="0" />
                            </parameter1>
                            - <parameter2>
                            <number>4.6</number>
                            </parameter2>
                            </boolean_operation>
                            <then />
                            </if>
                            </all_statements>
                            - <!-- End Logic Declarations
                            </logic>
                            </FusionControlCentreConfiguration>
                              ok, all that is good.
                              But that xml part I gave you is not able to be read in by the configurator. It is debug only code.
                              So after you put it in the xml file, open the main program, and the debug will popup.
