New Brain Owner
  • New Brain Owner
    That's right I have made the purchase. Hope to get it this week sometime. I have a demo I need to do with it and could use a little help. I would like to setup up a test area with a 12v battery and a on/off switch and a light bulb. I would like to have this done within RR application.
    I'm trying to understand the RRFusion app but this is all so new to me. I dont have the brain yet but it is coming. I heard that I could set up a virtual brain to build the app.
    I know this is just the beginning of what I'm trying to achieve but if I can figure this out it should better help me understand all the other thing I want to do with this brain.
    Thanks for the help in advance.
    Troy
    Batmaninls
    www.evorbust.com
    RRFusion = Not made by us
    Fusion Control Centre Uber MDX = made by us
    MDX has the virtual brain, and can be embedded into RoadRunner like any external application.
    RRFusion I dont know if it works without having the actual FB present, but it allows a button in RoadRunner to be used.
    1.9in x 2.9in -- 47mm x 73mm
      RRFusion is great! If you use RR as your frontend, its simple to add, you can create your own skin and the RR addin commands do all the work. I like it cause I have several things going on on the same screen i.e., I/O from RR, GPS, RRTMS, and RRFusion. As opposed to imbedding FBC in a screen by itself and losing the seamless integration.
        I keep hoping for both. I mean, the best of both worlds. I'd like to have seamless integration in RR, but I want the versitility and functionality of FCC. I think it would be the coolest thing since exhaust-driven turbos if variables from FCC were available to RR, in the same manner as direct readings and outputs are availble now with RRFusion. With RRfusion you can see if your door is ajar, but with FCC you can do something about it. I dunno, maybe I'm taking a narrow view, I thought that was why people wanted a functional COM for FCC. But maybe something else can be done. Maybe both softwares could work at the same time where some simple data is available in RR, and FCC takes care of my HVAC project, but probably not. And I really need some of the proccessed values available to me, and user interaction available to FCC. I guess I'm just stuck embedding it.
        Maybe 2K1Toaster should just evolve FCC into a fully functional front end!!!
        People say FCC is complicated but I don't think its more complicated than RR, not by a long shot. But maybe that's because I follwed it all of the way through and even tried to help guide it to it's current state.
        It's been a while...
          I have to agree. FCC is really a quite simple and elegant package once you "see what's going on." I suggest taking the sample skin included with the download and going through each element of it in the Configurator. That really provides a good insight of how it works.
          Thanks,
          Dan
            I want this to be a seamless integration using RR and Fusion Brain. You all are losing me.
            I want to have muliple gauges running in RR. All my car gauges.. I have Speedometer, State of Charge, Amps,Volts(car batteries running Motor), Volts Aux (this is the stuff in the car like lights and so forth) I would like to have them running all on one screen. These gauges are using Flash to make them work of course. Not sure that matters or not.
            But I wanted to turn on a light by switching an image on/off for a demo on Sunday. I know you all know how to accomplish this goal. I'm reading stuff as much as possible and 2K1Toaster is helping me setup a virtual brain so I can get to setting up and breaking stuff which I appreciate greatly. So is there like a diagram out there or something to show me how this is done?
            As always any help is greatly appreciated.
            Troy
            Batmaninls
            www.evorbust.com
              If you've got a show on Sunday, you need to be knocking out your screen graphics, now.
              For me designing the graphics layout is always the hardest part. Building it in Photoshop by modifying an existing PSD is not too bad if you already have the PSDs handy. Then there's the arduous task of overlaying the .skin file.
              If you're just adding buttons to an existing screen, no problem, just add indicators, buttons, and text labels to the .skin and make your indicators slightly darker than the text. No graphics changes needed. From there, once you get the FB, run your sensor wires and its just test and tune. Voila!
                If you want seamless integration in RR, the only thing that does this, to my knowledge, is RRFusion. You can embed a FCC window in RR, there would likely be seams. But you say you have flash guages already, for RR? In a RR skin? ok then the answer for that would have to be utilizing RRFusion at the present time. I haven't kept up on that thread (though I mean to) but it seems that guages will take some work and customizing, my understanding is RRFusion works with buttons and labels. If your guages are in FCC then again, you can embed it in RR.
                Troy
                Are you using FCC to turn this light on? I ask because of some of the stuff written above? If so, then power the light via a relay, connect the coil of the relay to a digital output on the board. THen you have to configure that digital output in the configurator. Then you have to make a button in a graphics page ( you should have an on image and an off image ready to go by now) . open the button's property page and .. link the images, link the output and you should be good to go. It's a pretty broad question, but any specifics you have questions about can be gone over in more detail.
                  Here you go...
                  This is what I want to have going on. I want to click this button and have the image stay the direction. It looks like the RRFusion skins is setup to have the ability to do this. This is why I need it to be seamless.
                  I have the RRFusion installed I think. I have followed all the directions you all are providing me. All I need is my BRAIN..... LOL LOL LOL ok my Fusion Brain.
                  It looks like I'm going to need a couple Fusion Brains to run all this stuff. Not sure 20 analog will be enough at this point.
                  Well let me know what you all think.
                  Troy
                  Batmaninls
                  www.evorbust.com
                    Since you are putting it all on the same page, why not just embed FCC? RRFusion will work but it is more adept for little things on lots of pages. That is its major advantage. If everything is in 1 spot, then you can use either and it will look the same.
                      Ok I just want them to look and operate correctly. I understand the word embed but how is it done. I have the MDX Software installed and I have added in the RRFusion app for the one off things. Do you build this page in MDX? and then add it to RR somehow? I will have like 3 pages of stuff like this to run the car. But I'm lost I guess. You guys make this sound like it is a cake walk and I'm sure if I understood it all it would be... Helps Me Please...
                      Troy
                      Batmaninls
                      www.evorbust.com
                        ...You guys make this sound like it is a cake walk and I'm sure if I understood it all it would be...
                        Personally I think its a bit late to try learning something that you don't understand for a show demo in four days. You are just begging for malfunctions and embarassment at the show.
                        Thanks,
                        Dan
                          Have you checked out the FAQ's for RR? Or searched for embed application in the forums? Here's two off of the top of RR's FAQ. I hope they help. Because their author and maybe some of the active RR coders/skinners would be best suited to give a good answer.
                          http://www.mp3car.com/vbulletin/rr-f...cation-rr.html
                          http://www.mp3car.com/vbulletin/rr-f...in-screen.html
                            LOL Dan, This demo is nothing more than 10 guys sitting around a table. I belong to a EV Club and there are at times like 20 people but for the most part there is like 10 of us. I was asked if when I was close to give a little demo of how this software would work. I have a meeting on Sunday that's all.
                            h3rk, I have so far been able to get a background image loaded into MDX. I have created a virtual brain for now until mine gets here. So how to get the xml file or config file to run so you can look at it out side the XDM edition configurator?
                            Once I have that I can embed it into RR I think I have played with loading Excel and other apps into RR.
                            Well that's my next step.... I can take a snap shot of what I have it that would help.
                            Batmaninls
                            www.evorbust.com
                              LOL Dan, This demo is nothing more than 10 guys sitting around a table. I belong to a EV Club and there are at times like 20 people but for the most part there is like 10 of us. I was asked if when I was close to give a little demo of how this software would work. I have a meeting on Sunday that's all...
                              Good. That changes embarassment to ribbing from the guys when it acts up.
                              Thanks,
                              Dan
