New Member Project
  • New Member Project
    Hi!! I am brand new to the Fusion Brain. I am building an airplane (Dragonfly) and found the number of items I wanted to monitor on my engine exceeded my panel space. I ran across the Fusion Brain and it seems the exact thing I need, at a very reasonable price. I want to monitor and alarm:
    Coolant Temp
    Coolant Pres
    Oil Temp
    Oil Pres
    O2
    Knock
    RPM
    Fuel Level (main tank)
    Fuel Level (Header Tank)
    Voltage
    Current
    Exhaust Gas Temp
    I am still in the Proof-of-concept stage.
    The FB is perfect for what you want. Even though this version does not have enough inputs for what you want to do. I would get one and start working with it. Or you could get 2 and have more than enough for what you want to monitor. Plus you can use it to turn on lights and such.
      I'll be using a FB to measure all of those except knock (since I don't have a knock sensor in my engine), so as soon as mine arrives I'll be putting up a write-up, if that helps.
      http://sticksout.blogspot.com
        Let us know if you have questions about it.
        1.9in x 2.9in -- 47mm x 73mm
