problems with drivers
  • problems with drivers
    When I try to add the brain in the configurator, it says " drivers not installed, LibUSB DRIVERS NOT INSTALLED PROPERLY. I down loaded the all the software and drivers, do I need to put them in a special place or something? Da fusion brain show up in the device manager , working properly. whats the deal?
    https://www.facebook.com/hinnantdesign1
    "da fusion brain" is the old drivers. use device manager to update to the newest drivers, located in your MDX install directory.
      thanks, I got it to work
        Since I got it to work, I added a analogue input ( steering wheel control). how do I list or put all the values of each button press and what program class to use?
          http://www.mp3car.com/vbulletin/fb-d...-controls.html
          right there.
            I already know how and have the values for each button. I need to know how to plug them in on the configuator? thanks
              look at the last post in that thread.
                And if you are using RR, you can now use the COM object to send it directly to RR without keyboard emulation. You can read up on that here: http://www.mp3car.com/vbulletin/fb-s...ig-update.html
                1.9in x 2.9in -- 47mm x 73mm
                  what about streetdeck? problem I found in the past when I tried a year ago was the class changed every time I open the program.
                    You can use the send key to foreground which works in any app without needing to know class name or anything.
                    Or you can use send key with just streetdeck and it will search open windows for one with "streetdeck" in its title/class automatically and send it there.
