Another Newbie with a question!
  • Another Newbie with a question!
    I have been looking through the boards for a couple week, and have seen where people use a virtual brian for testing. Those all seemed to be with the older version of the fusion software. Is it possible to set up a virtual brain with the "Uber MDX" version?
    If you click on the ladybug in the configurator, there's a box you can tick for a virtual brain. You can inject and control the values it receives to illicit the responses you want.
    DON'T PANIC.
    Previous install pics in 2k3 S10
    Project CarPc V2
      Originally posted by stealinfool View Post
      If you click on the ladybug in the configurator, there's a box you can tick for a virtual brain. This may not be what you think... It coincides with a brain you have plugged in (so you have to have one on hand) but you can inject and control the values it receives to illicit the responses you want.
      no, you don't have to have one on hand.
        My bad. I guess I've just always had one. I shall edit.
        DON'T PANIC.
        Project CarPc V2
          When I click on the ladybug this is the window i get. I see where it says virtual brains, but i still cant figure out where to create one.
              ok, i'm with you so far. i have master enabled
                and you've added a brain to the skin? there should be a checkbox under virtual brains.... what do you have?
                  it is enabled and there still isnt a checkbox
                    Nevermind, I figured it out.
                    Thanks for pointing me in the right direction or i would have been totally lost.
