Heated seats control
  • Heated seats control
    Installed some after market heating elements into my seats for heated seats. They came with a 3 position switch, OFF, LOW, and HIGH. How would I hook these to the FB>?
    I assume off is just no power. But low and high just need a relay each. So 2 outputs on your Fusion Brain.
    1.9in x 2.9in -- 47mm x 73mm
      How Would I map that into One toggle button, or would I have to have 2 Buttons?
        you would make the button increment a variable. then in logic check the variable against 1 to do stuff A and against 2 to do stuff B and against 3 to reset to 0.
          Got ya, thank you!
