where to start
  • where to start
    I bought my FB a couple of years ago and struggled. I have now come back to it and everything has changed.
    I have a carputer, and want to control winamp through buttonson my dash (volume, play, stop, rwd, ffwd(
    I have read through the tutorials but have a few questions first.
    1. Can i develop on my vista machine even though my carputer will is XP?
    2. do i still need to develop a skin, even though i don't need to see the output?
    3. can the volume control control master volume now (rather than winamp volume?)
    1 Should be no problem. I have a VB program I wrote on XP & works/edits fine in vista 64, can't use MDX on 64bit though. Next test is win7 32bit (quick trial did some wierd things, not sure if it was a problem or just something else goin on)
    2 nope, just make the logic do it all
    3. not sure, it's going to depend on how you are interacting from MDX->Winamp/windows (not sure if MDX can do that yet, VB could)
      also, when using the mdx i get told there are no fusion brains connected, does it not support the earlier versions of the brain?
        which version do you have? works fine for both my version 3 and version 4
          Make sure you specify brain version 3 in the config file.
          Thanks,
          Dan
            i am not sure which version i have, i bought it in Jun/Jul 2007
            here is a pic.
              that's a v3. You need to open the .xml and change the version.
                thanks, but i do not think i have got that far yet.
                my brain is powered, and linked to usb.
                i open "MDX configurator"
                and click on add brain
                the "brain form" pops up.
                and i click the magnifying glass next to ID.
                i then get an error message saying "no version 4 brains were detected" and "no version 3 brains were detected"
                fallen at first hurdle?
                  hold on, no lights on the brain. and a puff of smoke from the 1 of the 2 smaller chips.
                  i guess that's not good?
                    actually the chip has a crack in it... guess that's not good either
                      Nah dont worry, lots of chips have cracks in them!
                      Thats a joke :P Sounds like you blew a driver chip. That typically means one of your outputs is shorted.
                      2001 Mustang Convertible Worklog
                      Indigo Custom Frontend (Flash/Delphi)
                      Blog
                      Qube v1.3 Now Available at the mp3Car Store!!!!!!
                      The simplest IO controller you'll ever use!
                        i am not using any outputs
                          or you hooked up your power supply backwards. either way, not good.
                            ok, quite certain i haven't unless the power supply in the house has a positive outer, i'll check this tonight.
                            i've ordered a new brain. it looks like the project is on hold again.
                              what a numpty,
                              i tested the power supply with a chepo battery tester, 12v +ve inner, great no probs.
                              when i tried it again (after blowing the brain, i thought i'd reverse the battery tester, still 12v ... hmmmm ... the power supply was 12v AC!!!!
