FB not being detected
  • FB not being detected
    I just received my FB v4 in the mail today and hooked it all up. While it does work when I run the Control Center, the Configurator and the VB example both cannot find/connect to the FB.
    Like I said, I can set it up in MDX, MDX just cannot see it.
    I am running Window 7 Ultimate x64. Are there known problems already, I haven't found anything similar yet.
    Also, because it is not being detected, RR cannot find it either.
      There were reported issues with the drivers on 64bit OS'. Take a look at this thread if you haven't seen it already.
      http://www.mp3car.com/vbulletin/fusi...in7-32bit.html
        Copy the hardware id of your FB from the devise manager and it should work.
