Send Key
  • Send Key
    Hi All,
    I've read a few old threads about my problem but haven't found a working solution.
    All I want is to be able to do is have my FB simulate a keyboard stroke to use with Centrafuse. I'm using the voltage divider connected to my reverse lights so that I can hopefully get FB to tell Centrafuse to switch to the Camera plugin automatically using hotkeys.
    I have everything set up and working fine but no matter what I do I just can't get the send key feature to work.
    If I connect my FB output to a relay it turns on but if I change the output to send key it never seems to work. Neither send key or the foreground version seem to do anything.
    I've even changed the hotkey in CF to "F10" just in case there was an issue sending multiple keys.
    Has anyone ever had any luck doing what I am trying to do?
    Did you make sure all the details are entered in the SendKey options?
    1.9in x 2.9in -- 47mm x 73mm
    Buy now in the Store
      Yeah I did. I tried every possible thing I could think of to try and get it working.
      I'm actually using a CF plugin called Centrafusion that does exactly what I was looking for.
      Thanks for the reply
