FB Password Protected +12V Output
  • FB Password Protected +12V Output
    Ok so I am new to the fusion brain concept. Before purchasing i want to know that it will work for what i want.
    Here is the list of what i want to use a FB for:
    -Photo sensitive head lights
    -Password Protected switch that will provide +12V ONLY IF PASSWORD IS CORRECT (Maybe possible to use USB finger print scanner input as password) would prefer this feature to work standalone from pc but not madatory.
    -Monitoring exterior temp, Battery Voltage, Water temp, Oil Temp, Transmission Temp, Exhaust Gas Temp, and Oil Press.
    -Remotely Controlled solenoid (used like a door acuator when remote is pressed will pull for a set time then will release after set time)
    This is all for now..... Maybe if all this works i can expand.....
    Any usefull links to set this up would be appreciated. Also a list of what i would need to do all this would be amazing. Open to any helpful or useful advice as well.
    http://store.mp3car.com/Photosensor_p/com-076.htm
    The Fusion Brain needs a computer, though you might want to look at the Interceptor addon
    http://store.mp3car.com/Thermometer_p/com-077.htm
    Battery Voltage,
    Big resistor, or (preferably) http://store.mp3car.com/4_Channel_In..._p/com-118.htm
    same as above, but you might want different physical sensors (consider the temp range)
    and Oil Press.
    http://www.mp3car.com/vbulletin/fb-s...re-sensor.html but ensure its intended for oil, there are a lot of different rubbers out there (as I'm sure you know )
    http://store.mp3car.com/10pack_of_25..._p/com-085.htm
    Other:
    http://www.mp3car.com/vbulletin/fusi...press-etc.html
      Try the Arduino Duemilanove etc (ATmega328 CPU).
