problems with data logging
  • problems with data logging
    I'm having problems getting the data logging feature working correctly. The only way I can get it to work at all is using the GUI timer. If use any other timers it doesn't record. Also I need to record at around 1 data point a second and no matter what I set the GUI timer to it records around 12 data points per second. Can anyone help me out?
    I figured it out. Everything works correctly in Windows 7 64 bit except the timers. I set it up again on a XP laptop and the timers worked correctly. It also worked in 32 bit Windows 7 using the logic timer.
      Interesting... So the timers dont work in Win7 x64? I have not seen this before. I will log it as a bug and figure it out.
      Thanks!
      1.9in x 2.9in -- 47mm x 73mm
