Fusion brain not supplying enought power???
  • Fusion brain not supplying enought power???
    I am using the RRfusion plugin to control my fusion brain. I am using just and ordanary automotive relay. In when i tell the fusion to turn it on and hold it it holds it then switches off then back on. holds it then switches off then on. Not sure what is going on. I have a nasty hum as well from the relay. What it seems like that the fusion brain is not suppling enough power. When i hook the relay to the powersupply directly no humming happens.
    Mike
    what is the coil current and coil voltage of your relay? What is your power source to the FB?
    1.9in x 2.9in -- 47mm x 73mm
      Here is the relay i am using. My powersupply i am using with the fusion brain is a 13.8 volt at 15amps
      Mike
        What is the resistance between the coils. You can get a relay that switches at 12v for 30A that draws 150mA to turn on the coil, or ones that draw 600mA to turn on the coil. Both switch 30A, but one takes more to just be on then the other.
        Also, it is a 14v relay, and you are powering it with 13.8v. If you are using 13.8v (guessing you are simulating a car?) use a 12v relay.
          its is a 12v realy. When i plug the relay direectly into into the power supply i get no humming at all. That tells me the FB is not suppling the the correct power
            I will messure the resitance when i get home.
              When you plug it directly into the power supply, you are feeding it the same voltage but there is a huge amount of current capability from the power supply. Basically that relay could use up to 15A and work just fine.
              However, the FB current limits the outputs. If you try to push 15A through the FB it will melt. So it limits it to 500mA per channel, it is happier and cooler around 300mA to 400mA. So if your relay takes 501mA, it wont work. The voltage is fine, but there isn`t enough current. That`s why we need to know what the coil current is for the relay.
                Any news about your problem themlruts???? I have the same issue...
                  No news just looks like i need to use a differnt relay. Not happy about it since i have a boat load of these relays.
                    Im Using two Kinds of relays... with both the same problem... (T9AS5D22-12 AND JQC-3F-L) the first ones I bought them with my FBs (i BOUGHT 2 FB) in mp3car... the other ones bought them here in Chile. The last ones needs just 50mA to trigger, with 12vDC...much less than the MP3car ones... but still the problem.
                    now I will try with two different computers WITH DIFFERENT S.O.. maibe its a communication problem.. Im really tired of this...
                      That's a defect, no question. Email us and we'll get you a RMA.
