Fusion Brain Version 6 -- Firmware Update Version 2.0A
This is a sticky topic.
  • Fusion Brain Version 6 -- Firmware Update Version 2.0A
    Bootloader Application: http://www.fusioncontrolcentre.com/F...bootloader.exe
    New Firmware -- Version 2.2A: http://www.fusioncontrolcentre.com/F...013___2_2A.hex
    Steps:
    • Download the bootloader application from above
    • Download the new firmware from above
    • Plug in your Fusion Brain Version 6 via USB
    • Short the RESET pins together using a metallic object being careful not to short anything else. The use of a 0.1" jumper is recommended, but a screwdriver works just as well. The RESET pins are the 2 pins that are vertical between the USB jack and the analogue input pins on the USB and power jack side of the board
    • You should now see lights sort of blink back and forth on the only horizontal row of digital outputs (24-31)
    • After some time (many seconds) they will stop blinking back and forth and you should see the Fusion Brain connect to your PC as a bootloader device
    • If you do not have the drivers installed, they will automatically be downloaded from Windows Updates
    • Once the device is attached and the drivers are functioning you should see it listed as a "Custom USB Device" in Device Manager
    • Open up the bootloader application
    • You should see it say "Connected"
    • Choose "Open Hex File"
    • Select the firmware that you downloaded
    • Choose the "Program/Verify" button
    • Wait for all the messages to stop and it to display finished
    • Unplug and completely de-power the Fusion Brain Version 6. No lights should be lit
    • Calmy count to 2 to give the board a chance to fully die. The filtering caps try to keep it alive even without power for a good time.
    • Then plug it back in and it should be updated and back to normal. If not, then go back to shorting the RESET pins and reload the firmware. I have never had the firmware fail to load however, so if this happens please let us know.
    1.9in x 2.9in -- 47mm x 73mm
    Done! How can I verify new firmware installed?
    Old School MP3CAR.com member!
      Use the COM port and see if "a?" and "A?" work
      Actually I am going to add a firmware revision to the firmware.
        Inputs work in hyperterminal! thanks!
          Can I play with PWM in hyperterminal yet? Outputs ALWAYS flash, still. btw
            Ok now the firmware update (http://www.fusioncontrolcentre.com/F...20_05_2011.hex) now has Firmware revision and update date. To check revision after downloading, use the COM port and send a "*IDN?" request. You will now see something like:
            Code:
            >*IDN?
            *IDN?
            Fusion Control Centre
            www.FusionControlCentre.com
            SN: -1077923856
            Firmware Revision: 1.2
            Firmware Date: 20-05-2011
              Updating AGAIN..
                Ok I see what you mean. I must have broke something... Strange. I will look into it tomorrow. (Well today, but after sleep)
                  *IDN?
                  SN: -1077923856
                    Updating AGAIN..
                    But it is so easy and fast, it is almost a joy right?
                      Works great!
                        Ok new firmware uploaded
                          Firmware is updated again. Make sure you get the newest. There will be another update tomorrow or over the weekend as well. 1.2d fixes the "flashing" of digital outputs through FuseGL. The next version will fix it for the COM port too. I just need to do ASCII to integer parsing and it will be all good.
                            i have a small request that could be added to the firmware perhaps. Could the A? line (or some variant of) return all the values on one line with a delimiter instead of multiple lines. I'm having trouble reading the entire return.
                            Live mp3Car Facebook Chat
                              Yeah, it used to return a nice little list, now its a full screen affair.
