fusion brain and riderunner
  • fusion brain and riderunner
    right now i'm using a set of mjs usbio1's and they have been so easy to implement into my ride runner skins. I've been looking around and havent found any documentation on how to incorporate fusionbrain into the exectbl in riderunner. for example. i created a button on my menu.skin that could toggle one of the relays.
    this is how i do it (in the execTBL) with usbio1:
    Code:
    ”MJSGIO_SETRELAY;1;1;2”
    this will set the first board's relay #1 to toggle on and off
    if i just want it to just turn on the relay id do this:
    Code:
    "MJSGIO_SETRELAY;1;1;1"
    and to just turn it off i'd do this:
    Code:
    "MJSGIO_SETRELAY;1;1;0"
    is this something that is easy to do with fb? if so, can someone give me an example?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    It helps when you are the creator of the software and the hardware. Mitch is close with RR and it shows.
    I would talk to Sonic about RRFusion, it sounds like what you are looking for.
    1.9in x 2.9in -- 47mm x 73mm
      how did i miss that. i may finally bite the bullet! fb has always scared me, this makes it a lot easier
      M10k
      My Car Pc Install
      My Boat Pc worklog
        I would PM him or make a new thread or just search to verify it is FBv6 compatible. I sent him one for free so he could get it up and running, and I think he had it working but you may want to confirm if this is important to you as like I said, I don't support it.
