Lighting Timers
  • Lighting Timers
    Hello I was wondering if anyone had used the fusion brain for home lighting? I would like to be able to set the lights on timers, is this possible? Would anyone be willing to help work on this? it would be very useful for me.
    You may want to check the Homeseer (sp?) forum. There is a guy on there who has made a plugin to homeseer for the fusion brain. But if all you want is home automation, then there may be a more all-in-one packaged solution those forums may lead you to as well. Just depends on your skill level and what your end goal is.
    But to answer the question, the FB can definitely be used for controlling lights or any signal like that through the appropriate relay and wiring.
    1.9in x 2.9in -- 47mm x 73mm
