Configurator wont load
  • Configurator wont load
    Hi All
    I am just getting back into this after a few years out and after re-downloading the software and installing it, the Fusion Control Centre Uber MDX edition loads fine, but the Fusion Control Centre Configurator will not load, i get the following error:
    FCC Uber MDX Configurator has stopped working
    Any ideas?
    I am currently running windows 7 - 32bit
    I have all required .net versions and DirectX
    I installed version 4.0 and that then got updated by the auto updater
    the hardware i have is version 3 or 4, i cant remember right now but i'm not even plugging that in yet...
    Thanks in advance
    Ken
    Prepping for Trax in september
    Re-Building the whole CarPC to upgrade all the software
    Whole new boot build and moulding my screen into the dash...Again
    you might try attaching the brain & loading the drivers, the configurator may look at the driver for some reason. been a long time since I've used MDX.
      Originally posted by KennyKen View Post
      Hi All
      Any ideas?
      Thanks in advance
      Ken
      First thing to check is you run it as an administrator if you have UAC enabled.
      MDX is dead essentially.
      1.9in x 2.9in -- 47mm x 73mm
        Bingo - Thats sorted it :-)
        I should have thought of that myself really, Thanks anyway!
