Almera n16 pc
  • Almera n16 pc
    I would like to install a car pc in me vehicle, but i find one problem. As you can see on the pic below i already have a display (as far as i know vfd display) which shows all the data from climate control, outside temp, radio etc. I would like to remove it and put touch panel instead with car pc. The problem is how to get all those info from this display to a pc and then to a new display? i dont wan to control hvac with touch panel cause its done with a centre console which also operates radio. Any ideas, suggestions?
    If you just want to display and not control, then that is a simple job. Each of those VFD or LCD segments has a pin. Or worst case it is a matrix. The logic would be to just check when that segment is told to go high, and then display whatever on screen what the combinations of segments light up.
    1.9in x 2.9in -- 47mm x 73mm
    Buy now in the Store
      well how to figure out if its a matrix or not? all i know from manual is that the display is connected to radio, combination meter, multi function switch and ac - auto amp and has 24 pins (if not mistaken) if its any help i can insert pics from manualClick image for larger version
ID:	2284724Click image for larger version
ID:	2284725Click image for larger version
      thanx for any help
