Need help with my fusion brian
  • Need help with my fusion brian
    I am new to the whole Fusion Brain stuff, and have recieved a fb v6 that I ordered a few days ago. I have been trying to get it setup to run under Ubuntu 12.04 with no luck. I tried following http://www.mp3car.com/vbulletin/fusi...ml#post1291726, but I keep getting some errors. I have also tried as said here, http://www.mp3car.com/vbulletin/fusi...ml#post1447278, but it responds
    Code:
    [email protected]:~$ dmesg | tail
    [   23.742600] atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
    [   23.742612] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
    [   23.746336] atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
    [   23.746351] atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
    [   46.356272] usb 3-1: new full-speed USB device number 2 using ohci_hcd
    [   46.679572] cdc_acm 3-1:1.0: This device cannot do calls on its own. It is not a modem.
    [   46.679586] cdc_acm 3-1:1.0: Control and data interfaces are not separated!
    [   46.679701] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
    [   46.686315] usbcore: registered new interface driver cdc_acm
    [   46.686325] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [email protected]:~$ echo *IDN? > /dev/ttyACM0
    bash: /dev/ttyACM0: Permission denied
    [email protected]:~$ sudo echo *IDN? > /dev/ttyACM0
    [email protected]:~$ ls -l /dev/ttyA*
    crw-rw---- 1 root dialout 166, 0 Oct 28 15:55 /dev/ttyACM0
    I have been around linux for a few years but have never needed to to any programming outside of minor html/php, and a couple quick shell scripts to to some automatic stuff. The FB will eventuly go in my car when I get enough money for more stuff. I am hoping to use Ubuntu 12.04 or another LTS that they have when i install it, but am willing to use another linux OS if needed.
    Code:
    Are you wanting to use bulk USB, or USB-Serial?
    1.9in x 2.9in -- 47mm x 73mm
