Documentation - All Sensors
This is a sticky topic.
  • Documentation - All Sensors
    Triple Axis Accelerometer
    Freescale MMA7260
    Datasheet
    Current Sensor
    Allegro ACS754-050
    Datasheet
    Photosensor:
    Updated 14/04/2009
    TAOS TSL12S
    Datasheet
    Temperature Sensor:
    Microchip MCP9701A
    Datasheet
    Also has a 1uF noise filtering capacitor rated at 105 deg C. Advise removal or replacement of capacitor for >105degC
    IR Distance Sensor
    Sharp GP2Y0A02YK
    Datasheet
    Ultrasonic Distance Sensor
    Maxbotix EZ1 (Shipment Pre March 2008)
    Datasheet
    Maxbotix EZ0 (Shipment Post March 2008)
    Datasheet
    Volume Control (Rotary):
    10kohm Pot
    Volume Control (Linear):
    Alpha Model RA4545F-20G-15LC-B50K-C
    45mm travel 50Kohm
    Datasheet
    Thanks for pointing me to the data sheets.
    I cant find the pin outs for the accelerometer. I assume P1, P2, and P3 are for each axis, Which side does the red (+) wire go to? Also, what is P4 used for.
    Thanks,
    Glenda
      red/+ goes towards edge of board. P1/P2/P3 are for each axis - it'll respond to gravity, you'll see.
      P4 are jumpers to change the sensitivity.
      You'll probably want to do some noise filtering. high sample rate + averaging will do.
      http://www.mp3car.com/vbulletin/fb-s...e-example.html
        "P4 are jumpers to change the sensitivity." Anyone have a link to a retailer that sells these jumpers? - they did not come with my accelerometer.
          Any 0.1" jumper will fit. They are the standard jumpers found on the backs of harddrives, CD/DVD drives, pretty much anything. You can buy them lots of places. If you are in the US, then Mouser/DigiKey/Jameco all sell this stuff.
          1.9in x 2.9in -- 47mm x 73mm
            If my current sensor has R0903113 on it, is it a Allegro ACS754-050?
            thanks,
            charles
              thanks,
              charles
              If you bought it from us, and it looks like the picture, then yes.
                Hehe, well I just want to be sure after the relay debacle. Have you considered putting links to to appropriate docs on each oscommerce description page for the products so they are easy to reference? That way if you get a different model/version of a product each will have a reference to the right docs for it.
                  Jumper settings
                  Any chance of getting a description of the jumper settings?
                    relay: what connects to what?
                    What are the three connections on the relays for? I suppose one is + one is - and the other is ? There is no indication on the male pins. I assume that the power out is very small? So, say I want it to switch on a 110v outlet. What do I need?
                      It is a standard relay.
                      There is a common, a normally connected, and a normally not-connected.
                      Relays have no polarity. The coil sides are wired to the little header pins that plug into the FB.
                      You can switch 25A with these relays. If you want 110vac AC then just connected to common and either NC or NO depending on how you want it to work.
                        Check out post #4 in this thread for a good visual on using a 120VAC relay:
                        http://www.mp3car.com/vbulletin/fb-s...ml#post1429125
                        Thanks,
                        Dan
                          nothing is standard
                          Geesh... you explain, like a doctor... or worse... an accountant!
                          What is the purpose of a "normally not-connected" pin. "Common" is common to what? Where do I get the mating connector for these relays and what are they called? (Perhaps you sell them as well?)
                            Perhaps a general read up on relays will help. Look at this part of wikipedia: http://en.wikipedia.org/wiki/Relay#Pole_and_throw
                            Explains NO, NC, and Common. We sell SPDT relays so the picture there should help too.
                            The mating connector for the FB is already soldered on. The mating connector for the relay terminals is a generic spade connector. Available at an auto store or even Radioshack.
                              You can likely get a 100 pack at Autozone for the price of 5 at Radioshack, or such was my experience...2 years ago...
                              (The Volume Control (Linear Variable Resistor) datasheet doesn't give a pinout, and I seem to have lost my multimeter)
                              ((The supplied cable isn't soldered to the resistor, which is fine but still need to know which is power, ground, the analog signal, and if the LED should be tied directly to the +5V (likely not! ) )
                              Update: my findings
                              Last edited by UniqelyCommon; 06-15-2011, 10:50 AM. Reason: spade clarification, link to findings
