Fusion Control Centre Source -- Yep, all of it!
  • Fusion Control Centre Source -- Yep, all of it!
    UPDATE:
    Ok, here is the directory source files for the main MDX program, the MDX Configurator, the MDX Updater, and the FusionUSB.dll that we use to talk with the Fusion Brain. Folders are ordered by date, and project solutions and everything are all inside.
    If you have a good contribution to the source, email us and we can put it into the next release.
    Everything is open source here!
    SOURCE: http://www.fusioncontrolcenter.com/MDX/Source/
    1.9in x 2.9in -- 47mm x 73mm
    Also all of these were created using Microsoft Visual Studio 2005 Pro, but should be openable in Express which is free.
    The Solution (*.sln) file is included as well. The programs are all written in C# and the DLL is written in C++.
      I have downloaded the source files and get an error every time I try to extract MDX. The others extract fine. I downloaded it again just to make sure the download wasn't corrupted and still get the extraction error.
      Can you check the extraction on your end and make sure the file is okay? I am using WinZip 11.2.
      Thanks,
      Dan
        Just downloaded and tried again, works fine on this end.
        I am using WinRAR 3.70
          I just tried again, this time leaving out the embedded archive files and it stopped on 81.png. I'll download WinRAR and see how it goes.
          Thanks,
          Dan
            That worked like a charm. I guess WinRAR does something that WinZip don't like.
            Now, only 50 gadzillion lines of code to read...
            Thanks,
            Dan
              Dont hate me, but I had a new source file uploaded, I forgot to update the link...
              1st post is updated, and the link below is the most current: http://www.fusioncontrolcenter.com/M...2008-06-17.rar
                It's not so bad.
                I seperated it into regions to make viewing a bit easier and sort of explain. Comments are not really in there at all.
                  I'm from the "if it was hard to write, it should be hard to read" school of programming.
                  Thanks,
                  Dan
                    Just downloaded it now shall stick it on my dev box and have a play with it, Good work can get everything in order then for when I order the new board between "some time soon and the not so distant future"
                    Mileage Calculator and logger in progress check it out :)
                    http://img.photobucket.com/albums/v4...italcarsig.jpg
                      That's okay...I don't have a brain yet so I can use MDX anyway.
                      I do have a question about the Configurator. I see an icon for "Rotate Image"...what does it do?
                      Thanks,
                      Dan
                        It does nothing now. MDX can read it in if you code for it manually, but the config cant spit out that code yet.
                        Basically it is an image rotated around a centre point. Think of a guage needle, something like that.
                          What about something like a bar graph? I want to use something like blue->red for temperature gauges and digital output for most other stuff.
                          Thanks,
                          Dan
                            Multi-image
                              Cool!!! Time to play...
                              Thanks,
                              Dan
