Outputs hooked up to relays and then air valves
  • Outputs hooked up to relays and then air valves
    Air Ride Suspension Control
    Is this a question or a statement?
    1.9in x 2.9in -- 47mm x 73mm
      its actually both. Would the outputs be momentary or latched? Is this controlled thru software?
        In version MDX, it can do either.
        And yes, that is a proper wiring diagram.
          Trying to figure out how to wire up my setup and what better way than to sketch it..
            that's fine
