Buttons on my dash to turn on my car amplifiers
  • Buttons on my dash to turn on my car amplifiers
    Ok, so I am using the FB at the moment to trigger outputs (relays) for my amplifiers.
    I want to use a spare switch in my car's dash to do the same thing (as if I were clicking the button on the screen to turn on/off an output).
    The switch in my dash seems to only complete the circuit when the button is being pressed, once I stop pushing down the button, the circuit it broken.
    So I want MDX to change the output status as if the button is like a "down click vote" and not change until the next "down click vote"
    Hope this makes sense.
    [H]
    ____╔══════╗____
    OOO/ATT41\OOO
    Not quite sure of what you are trying to do here...
    Just to clearify...
    You want a hardware button, to do the same task as a software button via FusionBrain does?
    If so the case, you need a button that sends a puls signal while beeing pressed. then a system that register the puls, and have a memory of on/off state, and out of that a logic that sends a solid 12V to amp if "on" and cut the signal if "off".
    Now.. This might seem a bit more complicated than it realy is... There are some stores where you can buy a logic relay that can do this task for you.
    How this will work togeather with FusionBrain... I have NO clue off..
      hmmm... not quite.
      I think what I am trying to say is, I want an output to be triggered by an input.
      Once the input is active (lets say 12v) the FB will trigger an output.
      [H]
      ____╔══════╗____
      OOO/ATT41\OOO
        OK, I think I am getting somewhere now,
        using a new root function that will trigger a predefined output if a certain input is greater than 5v (I now realise you can have a input with 12v)
        gotta play around with it a bit though.
        [H]
        ____╔══════╗____
        OOO/ATT41\OOO
          do not do this. 5v is the max.
            oh ****, I meant to say can't,
            but it appears I have found a way to do it. I'm going to have an input logic "if > 2v, vote amp relay on",
            and I will have a second button in may dash that will do the same, except amp relay will turn off.
            just need to find a 5v source somewhere tho...
            [H]
            ____╔══════╗____
            OOO/ATT41\OOO
              take it off the FB analog inputs
                The virtual button in MDX acts like a momentary, or the physical button?
                If you want the button to act like a latch, then have the button input increment a variable. Set the minimum time between votes to something like a second or more. Then another logic that says if the variable is 1, turn on output. Another for if variable >= 2, variable = 0. That will latch.
                1.9in x 2.9in -- 47mm x 73mm
                  Great!
                  Makes sense, but I'm having trouble making MDX do that.
                  The first input logic will be "if amp switch is > 2v, then change variable +1"
                  it seem that when I punch that it, it doesn't add 1 to the variable value, it replaces it with the number 1.
                  Or am I doing something wrong? - I can host the config file if it helps?
                  [H]
                  ____╔══════╗____
                  OOO/ATT41\OOO
                    Looks like I have figured out a way to do it
                    For anybody else trying the same thing, this is what I am going to test with my FB (seems to work fine with the virtual brain so far).
                    Only problem I forsee is holding the button down too long. but I shouldn't be holding the button for longer than 1 second I suppose.
                    [H]
                    ____╔══════╗____
                    OOO/ATT41\OOO
                      "value = +1" means "value equals positive 1"
                      "value = d+1" means "value equals value plus positive 1"
                        thanks for that!
                        I ended up just replacing the numbers with 1 or 0, rather than adding and then changing the variable.
                        do you seem some flaw in the way I have done it?
                        [H]
                        ____╔══════╗____
                        OOO/ATT41\OOO
                          thanks for that!
                          nope that works fine as long as it stays synchronized which it should unless it glitches from what I can see.
                            well I'll see how it goes with the real thing, I just hope it doesn't miss a "then" statement.
                            [H]
                            ____╔══════╗____
                            OOO/ATT41\OOO
                              So I have been testing it for a little while. Does seem to open the relay on every click, seems to not register some times. I may have my vote timings incorrectly. I noticed you can change the vote timing for the whole file, or you can change the timing for each logic. Any timers I should have specifically?
                              seems the variable is always correct, and always changes. Sometimes the output isn't triggered through.
                              [H]
                              ____╔══════╗____
                              OOO/ATT41\OOO
