150 PSI Air Pressure Sensor
  • 150 PSI Air Pressure Sensor
    This is on its way to me:
    http://www.dakotadigital.com/index.c...rod/prd124.htm
    and I should have it by the end of this week. I will update accordingly.
    love at first site greenman.. o golly
      O.K. I'll bite. How are you going to hook that to your FBrain? Looks like it only has 2 wires and don't FB sensor inputs have 3? I only ask cause I need the same thing for my air horns.
        well, I got it today.
        You hook it up through a resistor network. We will provide the adapter cable, and you order the sensors directly from dakota digital.
          greenman, ur unreal. im excited! im excited im excited
            You hook it up through a resistor network. W[HL]e will provide the adapter cable[/HL], and you order the sensors directly from dakota digital.
            How much?
              cheap, probably $7-10. I'll tally up what the components cost.
                where are we at with this ???
                I want to place the order for the brain, 4 temps and a pressure switch ASAP.
                I figure if i gotta pay postage may as well be on the lot, rather than do it twice.
                  Originally posted by ginigma View Post
                  So is there some simple circuit (amybe just a couple resistors or something) that we could build ourselves? Until you get the "professional" ones done?
                  Below are the specs on the 150psi pressure sensor:
                  Code:
                  150psi, 1/8-27 NPT
                  PSI		R typical	R max		R min
                  0		10		13		5
                  14.5		31		35		27
                  29		52		56		48
                  43.5		70		74		66
                  58		88		92		84
                  72.5		106		111		101
                  87		124		129		119
                  101.5		140		150		130
                  116		155		170		145
                  130.5		170		185		155
                  145		184		214		154
                  Maximum 435 psi for 2 seconds only.
                  Operating Temperature:  -13F - +212F (to +248F max. 1 hour) on
                  connecting thread.
                    so, you just need a 180 ohm resistor. Wire it like this:
                    +5v
                    sensor
                    analog input
                    resistor
                    Ground
                      Hi All. Dakota Digital http://www.dakotadigital.com have these units SEN-09-3 which is a local pressure sensor for vacumme and 0-30 PSI pressure, ideal for measuring turbo boost. I have asked and they tell me the signal out is 0 to 5 vdc.
                      Perfect for the Fusion Brain, and the pressure is right in the range we want to measure so it is going to be nice and accurate.
                        seems that dakota digital has a lot of nice sensors. i wouldnt mind the tire pressure ones.. i bet they all work off of 5vdc..
                        cashtexts - Earn money for receiving text messaged offers
                        cashtexts review not a scam
                        Space Navigator - 6 Axis input device: Take it apart - Driver App
                        RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
                          I have a bunch of these with my air ride kit, if you have any graphical representations of how you wired it, please post!
                          Ampie Case
                          256 MB DDR2 PC5400
                          Xenarc 700TSV - VGA Monitor
                          Intel D945GCLF Motherboard
                          M2-ATX-HV
                          2005 Honda Civic
                            were we at with this?
                              The post above gives the range of values the sensor works with.
                              You want to make a circuit like this:
                              +5vdc-->100ohm resistor--->sensor signal lead and fusion brain input--->sensor--->ground
