Tilt angle sensor
  • Tilt angle sensor
    I purchased a Clinometer to measure the tilt angle of something. Thought I'd post some details for anyone looking for something similar.
    Part number 824-02110002, MSI Sensors, Clinometer, Single Axis, Vertical mount. Price of $137 plus shipping.
    This particular sensor is good to 60 degrees either side of center. It has no moving parts, but does contain a fluid which is what is used to determine angle. Unfortunately, that also causes a "slosh" effect while bouncing, so I did have to add some averaging to get it to move smoothly.
    This sensor is ratiometric, so you give it 5 volts, and it will output 2.5 volts when level. Output voltage goes up or down based on which way it is tilted.
    Mouser Electronics Part
    Data Sheet
    1.9in x 2.9in -- 47mm x 73mm
    Buy now in the Store
      Also take a look at they have a dual axis inclinometer that runs 5v interface similar to that described above. Would be great for anyone with a 4wd interested in seeing the side slope angle or angle on inclinatio going down or up a hill.
      Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
      Car- 1988 Nissan Patrol 4WD
        Hey, I've been looking for something like this for my Xterra. I don't have a nice spot for analog gauges, but I have my LCD in that spot.
        What would you use for software interface and to display the date?
