do the 3 meter extensions have an affect on sensor readings?
  • do the 3 meter extensions have an affect on sensor readings?
    I've got a few temp sensors installed in my car now. one travels the length of the car to the dash to get an inside reading and one travels to the outside of the car for the outdoor reading. The outdoor sensor seems spot on, but the indoor sensor connected to 3 extensions seems to not respond to temp changes accurately. For example, if i let the car sit in the sun it will read accurately once i start the car and drive off.. but as the a/c cools the interior the sensor doesnt report a drastic change in temperature. In my hour ride that started off with a 94F reading after sitting in the sun all day the temp only dropped to 79.. this is while i had the cars climate control set at 72F. It definitely wasnt 79 lol. So do those extensions have some sort of effect on the temp sensor or could it be that sensor is just not calibrated properly?
    Live mp3Car Facebook Chat
    It's possible there's a bad connection in one of the extensions, but more likely, the air around the sensor truly isn't changing. Where is it positioned?
      its dangled under the steering wheel.. i was careful not to allow the sensor to touch anything.. its hanging freely.
        Yup, I have one in the same position, with no extensions, and it doesn't drop that low in temp. The air there just isn't as cold as teh air being blown on your face/body....
        What I'm doing is a weighted average between AC duct temp and the under the steering wheel temp
          that makes sense and i just so happen to have a spare temp sensor. I think i'll try that.
