Outside Temperature sensor
  • Outside Temperature sensor
    Can the Thermometer sensor just act as a temperature sensor is mounted outside the car?? And used in RR to display the readings? Thanks
    Yes and yes... i have a temp sensor that is sitting underneath thes pare tire in my car. I drilled thru the metal and epoxied the sensor and it still gets fairly accurate readings. RR can display the data via RRFusion or MDX's COM link.
    Live mp3Car Facebook Chat
      Perfect!
        When are these things supposed to be back in stock??
          They are in stock, forgot to update the website.
          I will do that tonight.
          1.9in x 2.9in -- 47mm x 73mm
            Does it come with the header pin on the wires, or do I have to buy that seperate? If I do, Are the 3pin Female to Bare Wires in stock as well?
              Comes with header. Plug-n-play
                excelent! ordering right now. thanks
