Software v1.6
  • Software v1.6
    I see that this version comes with a COM object file. Can you give me some examples on how to interface to it and I'll help test?
    Also, how can I add a digital input on a skin. Something that will show the state of the input when I have something connected. This is just for testing, so it can be a simple "on/off" type image. Can you post an example of a skin file?
    How can I log the input values for data logging? It looks like earlier versions wrote that info to the UserConfig.atom file, but that's not used anymore.
    i am no expert, but to test my digital inputs i created a digital output and linked the input to the output. my skin then showed me when it recieved a signal.
      In the next upcoming version I will be unlocking the debug interface.
      More details will be provided upon its release, but basically it will show the status of everything. This is the raw screen with no byte stream going in (obviously as Vista wont let me communicate with it yet! )
      1.9in x 2.9in -- 47mm x 73mm
        Log file?
        Thanks for the debug info.
        How do I turn logging on? I haven't been able to figure that out. I thought I saw mention where a file (folder?) would be created with the sensor name, but I don't see that happening on my system.
          I'm not sure if I answered you in a PM or not, but to turn on data logging now you use the graph button. When the graph button is on, then it logs the data.
          Also you might have some input on this thread: http://www.mp3car.com/vbulletin/soft...ml#post1113500
